A detached garage was built then it was connected to the exiting house with a enclosed roofed breezeway. You can exit in to the breezeway from the old exterior back door and enter the new garage through a new exterior door on the garage wall inside the breezeway. The garage has an exterior door installed but no closer per 2012 R302.5.1. The code sez openings between the garage and the residence shall be equipped with a solid door and closer.
Would one closer on either door meet the code or just one closer on the new garage do the trick?
