Air gap btwn conc planter wall / wood framed wall behind it?
Yikes
Gold Member
Southern California
I 'm designing a new apartment project with raised poured-in-place concrete planters immediately adjacent to the wood-framed exterior wall of the apartment.
I first thought about simply building the wood apartment wall on top of he planter stem wall, but then I would need to furr-out on the inside of the bedroom for insulation, losing valuable floor space.
I'm not looking at doing a double-wall, where the wood-framed apartment wall extends down to slab-on-grade, and there is a second, separate raised planter wall next to it.
Question: years ago I remember something in the code saying I had to separate these 2 walls with a 2" air gap. Is that still in the code?
All I could find was a requirement in IBC 2304.12.1.3 to keep untreated wood walls out of "direct contact" with the raised concrete planter, with no specific gap measurement mentioned:
steveray, maybe that's the way to go. I still would have to work on the constructability of it. I.e., if it is a one-hour wood framed wall, do I need to build the foundaion, then the wall, lath-and plaster it, then re-mobilize the concrete sub to build the planter wall next to it? Or is there a way to stop the plaster short of the planter and have the planter wall itself become part of the one-hour assembly?
so many questions...
