For Accessibility inspections I use a digial 24" level on top of a 48" level.
24" Digital Level (click here)
I used the magnetic tip on my Fatmax to fish my work truck key out of a 5' deep storm sewer... true story. I always get the magnetic tip. Also very useful when you are up on a ladder or scaffold and drop a screw that you need. We use it to transfer hand tools up a 20' Perry scaffold sometimes, way faster than climbing up to hand someone their pliers, they just drop their magnetic tip down to you. I have also used it to snag a metal fish tape in a wall cavity through a drilled hole in the top plate. Well worth having to scrape the metal shavings that collect there off every once in a while.Still my all-time favorite tape measure. I love the magnetic tip, especially with so much metal framing in my area.
25' Magnetic Tip Tape Measure (click here)
The court appointed "Neutral Accessibility Consultant" (NAC) for City of Los Angeles tested a bunch of different digital levels and found that their accuracy varied by as much as 0.3%. This led them to state that when they field measure slopes, if the level reads 2.3% or less they consider it 'level', if it reads 5.3% or less they consider it 'not a ramp' and if it reads 8.6% or less they will consider it a slope-compliant ramp. Obviously, they do not allow architects to design to those numbers - - this only relates to field measurement once it is built.For Accessibility inspections I use a digital 24" level on top of a 48" level.
I’d suggest you create a playlist on the TBCF YouTube channel with brief product reviews of the things you have used. So, you take that flashlight and show people why you love it in addition to the affiliate link. Having these links on this forum sells to people who have come here for code-related information, there are a lot of people who use YouTube for product videos and most of those people would not think to look here for product reviews.These are products that I have personally used. These are Amazon affiliate links.
I saw one (similar) the other day at Home Depot. I was really surprised.A door installer gave me a tool just made to check the weight of doors with door closers. I don't know where you can get one but it's pretty cool, you just push the door open with it. Was using a fish scale before.
I also like this Kobalt elec. and GFI tester and contactless voltage tester.
It was by the tape measures in the SJ one.Huh. Now I want one.
I can taste electricity. YummmmmyI'm pretty sure that Jeff can smell electricity.
Anybody else doing this?A meat thermometer (to check water temp.)
I still have the old ones I bought when I went to Vo-tech for HVAC in 1990. Not instant read but they responded pretty quick. Old analog dial thermometers that we used to measure temp rise on a furnace. No batteries and you can recalibrate by putting in a glass of ice water. Just turn the nut right behind the head until it reads 32 degrees. Worked well for checking meat temp too.Anybody else doing this?
Any old meat thermo, or instant read?
Any recommended brand?
