I've only ever run across this type of construction twice, and both were in commercial settings, so I had to look it up. Here's what I found:
R603.2.6 Web holes, web hole reinforcing and web hole
patching. Web holes in wall studs shall comply with the
conditions as prescribed in AISI S230, Section A4.5. Web
holes not in conformance to the conditions as prescribed in
AISI S230, Section A4.5 shall be reinforced in accordance
with the provisions of AISI S230, Section A4.6 or patched
in accordance with the provisions of AISI S230, Section
A4.7.
R603.3.4 Cutting and notching. Flanges and lips of cold-
formed steel studs and headers shall not be cut or notched.
Interesting... I bet the product comes with a listing and instructions, which probably include some limitations even for non-loadbearing walls...Both of those sections apply to load-bearing walls and partitions. The voice in the video asked about NON-load-bearing walls. I can't find anything in the IRC to address this question, so the answer is probably to defer to the manufacturer's installation instructions (if there are any). From a practical perspective, I can't imagine doing that without following up with a steel strap on each flange to span the notches.
1-½”, according to the ICC-ES Evaluation Report, ESR-4205.
How is that different from wood framing in residential construction when the plumber way over cuts the hole.
All that text was directly quoted from the article I posted the link to.Where did you see that in ESR-4205? I can't find it.
I didn't say anything. I literally copy/pasted that whole statement from that website.Okay, but I downloaded ESR-4205. It doesn't say what you said it says.
