ScottB
We have a flat roof carport with a two foot overhang which is permitted to encroach into a required yard, however the underside of the roof within the encroachment is required to have a 1-hour fire rating from the underside. The proposed assembly (attached) of the roof is plywood over metal decking with rated gypsum like DensArmor Plus. We desire to keep the roof thickness as minimal as possible, around 4 inches thick max. The closest approved detail for this which we have found is the GA600 File FC 4503 from the Gypsum Association Fire Resistance Manual. This assembly (7.75") is thicker than we prefer. I am hoping that someone knowledgable on this topic can suggest a thinner approved assembly other that the FC 4503. Thank you, Scott
