13 Amps at the Ground Plate
A grounded conductor that has two different bonds to ground, putting part of the grounding system in parallel with the grounded conductor?
Cheers, Wayne
Do you know the answer, or are you looking for suggestions? Multiple scenarios can be the cause. I have several scenarios if needed.
Yes, I do know the answer, and sometimes it is quite simple, such as in this case. While I routinely find 1-2A in this scenario and see that as about normal, in this case, the culprit was the meter itself, which is a POS. This is why I only buy Fluke. I still think this is a good subject to discuss when the ECG or GEC has significant amperage. I will return tomorrow to see what it is with a real meter, a Fluke 87V. I will follow up with a post.
