16 oc in the front, 12 oc in the back
Hence the need for solid blocking.
Anyone disagree?
Anyone disagree?
Not me
R502.7 Lateral restraint at supports.
Joists shall be supported laterally at the ends by full-depth solid blocking not less than 2 inches (51 mm) nominal in thickness; or by attachment to a full-depth header, band or rim joist, or to an adjoining stud or shall be otherwise provided with lateral support to prevent rotation.
north star said:
+ +Do those joists have a 3" overlap? [ Section R802.3.2, `06 IRC ]?
Excellent point because the front of the foundation for the basement is backfilled and the back is a walk out with no backfill so what is going to keep the joists from pushing in in the front?
The basement wall must be built as a retaining wall.
No matter what the joist spacing may be, solid blocking is required between the joist.
ICE said:
[/b]The basement wall must be built as a retaining wall.
Hmmmmm. I wonder if the language of the code or the foundation section covers that in the charts for unbalanced backfill or does the unbalanced backfill charts assume equality on all sides of the foundation?????? Maybe we are thinking too much.
I don't know about the charts you are talking about. We don't have basements. The closest I come to what you are talking about is cutting into a hillside and that requires an engineered retaining wall.
