P3005.2.7 Building drain and building sewer junction.There shall be a cleanout near the junction of the building drain and building sewer. This cleanout shall be either insideor outside the building wall, provided that it is brought up to finish grade or to the lowest floor level. An approvedtwo-way cleanout shall be permitted to serve as the required cleanout for both the building drain and the building sewer.The cleanout at the junction of the building drain and building sewer shall not be required where a cleanout on a 3-inch(76 mm) or larger diameter soil stack is located within a developed length of 10 feet (3048 mm) of the building drainand building sewer junction.P3005.2.8 Direction of flow. Cleanouts shall be installed so that the cleanout opens to allow cleaning in the direction ofthe flow of the drainage line.Can someone send me the commentary figures for this? How can you have a "two way" cleanout if has to be installed so it cleans in the directions of flow?double clean out [1600x1200] [1600x1200].JPG[/attachment:1rwo8s6g]
/monthly_2010_05/572953db221ff_doublecleanout1600x12001600x1200.JPG.77393911817ea623ea14ecb0ec947860.JPG
