I am adding a large addition to a facility. The addition is about the same size of the existing facility. I want to avoid having to install sprinklers in the existing building (amongst many other code improvement requirements). I see two options:
1. Perform the code review as an addition to an existing facility and follow codes accordingly.
2. Treat the large addition as a "new independent structure", fire separate from the existing facility and follow different codes for each building (IEBC for the existing facility and IBC for the new facility).
Opinions & Question...Is it better to treat the entire "final" facility as one building with a large addition or do you think it will be better/easier to treat them as two separate buildings hence using the 2009 Existing Building Code for the existing structure and the 2009 International Building Code for the new structure. The existing facility and new addition will only be connected via a 40' long corridor (Essentially, it will be two separate buildings with a corridor connection.)
My problem is that the existing structure has large assembly spaces on the existing second & third floors which, if built today, would require a sprinkler system. Currently there are no sprinklers in the existing facility. I am worried if I treat this as one building I will be required to add sprinklers in the existing building because of the scope of renovations being performed.
The project will be using the 2009 Building Code Family.
Thanks in advance!!!
