AegisFPE
Silver Member
2012 introduces a new section 604.5 and a new undefined term "Emergency Lighting Equipment." What is Emergency Lighting Equipment?
Stookey's Significant Changes book has a picture of means of egress illumination equipment. But what about exit sign illumination!?
The reason for the code change cites a "gap" in maintenance provisions for means of egress illumination power equipment installed per 1006.3. However, Section 605.4 never references Section 1006.
So, then does 605.4 also apply to Section 1011 and/or 1030.4 for exit signs?
An ICC representative's opinion is that because exit signs are in 604.2, that 604.5 applies. I'm not seeing that one.
I see 4 reasonable options:
- 1. Means of Egress Illumination is accomplished by Emergency Lighting Equipment, therefore 604.5 is applicable to devices installed per 1006 or 1104.5 (2009 IFC 4604.5).
- 2. Exit signs are already specifically addressed in 1030.4, 604.5 does not apply per 102.10.
- 3. External Exit Sign Illumination is accomplished by Emergency Lighting Equipment, and therefore 604.5 applies as it prescribes more specific requirements than 1030.4, and therefore is applicable per 102.10.
- 4. The components within an internally illuminated exit sign (except self-luminous signs) constitute Emergency Lighting Equipment, and therefore 604.5 applies as it prescribes more specific requirements than 1030.4, and therefore is applicable per 102.10.
