2406.3 (6) Hazardous location
SCBO1
Platinum Member
MID WEST
What is meant by the 24-inch arc? Would this pertain to door swinging into a glass wall at 90-degrees.
An example would be nice if you can post it!
pc1
http://www.inspectpa.com/forum/showthread.php?909-Section-R308-4-in-the-IRC
Thanks, marc, I thought we covered this, I should have remembered Northstar's big ***** fonts!
The issue I have is like figure R308.4(6) but the wall extends further down the hall with glass, so the door knob and door would bang into the wall, unless a door closer was used, but I still think this applies.
pc1
Glass perpendicular to the door and on the latch side (see Figure 5). This exemption seems to imply that the danger is greater when someone could open the door and push an unsuspecting person on the other side into the perpendicular sidelite. Since they would be pushed away from the sidelite on the latch side, it is exempt, while the one on the hinge side is not. The perpendicular sidelite in Figure 10 requires safety glass because it is on the hinge side. This exception does not apply to commercial buildings.
http://www.ashireporter.org/articles/articles.aspx?id=2198
6. Glazing in an individual fixed or operable panel adjacent to a door where the nearest exposed edge of the glazing is within a 24-inch (610 mm) arc of either vertical edge of the door in a closed position and where the bottom exposed edge of the glazing is less than 60 inches (1524 mm) above the walking surface.
That is how my code reads......arc measured from either edge......latch side included.....
