Not attached to a structure, under 120 square feet = no permit required in any jurisdiction I know of. Slap it together any way you like, and when you get done building it, jump up and down on it and see if you like how much it bounces. If it's too bouncy, nail on a few more boards and call it good.
If you really want to do it "right", use 4x4 posts or larger posts on 12" diameter x 6" deep footings, notch the 2x6s into the posts so that they sit directly on the posts, rather than relying on a bolted connection that will fail over time, and install 2x6 joists spanning the long way across underneath with joist hangers every 12", (so you'd only need 2 in the middle, quantity of 4 10' 2x6s total, two in the middle and one on each side, and then quantity 2 3' 2x6s for each end.
Obviously the second structure will last longer, but if it gets hit by a hurricane it probably doesn't make a difference.
