Thanks north star, but once again I have trouble clarifying what I meant.
To my knowledge the IRC does not address "openings" where the code allows 5/8ths for the ceiling instead of the separation wall to the underside of the roof deck in accordance with section R302.3 exception 2. 2009 IRC
"Wall assemblies need not extend through
attic spaces when the ceiling is protected by not less than 5/8-inch (15.9 mm) Type X gypsum board and an
attic draft stop constructed as specified in
:Next('./icod_irc_2009_3_par079.htm')'>Section R302.12.1 is provided above and along the wall assembly separating the
dwellings. The structural framing supporting the ceiling shall also be protected by not less than 1/2-inch (12.7 mm) gypsum board or equivalent."
Then there's requirement for attic access; R807.1
Since this is not a 1 hr. horizontal assembly but a 5/8ths Type X ceiling (40 min.) what criteria if any do you use approve a horizontal assembly for this membrane opening?
For example a typical attic access has wood trim holding the cover above, do you consider the thickness or type of wood and fasteners for equivalency?
If they were to cover an attic access ladder with 5/8ths what about the hinges and screws attachments?
