Building a small duplex. 2 units 768 sq ft. Small town. One plumbing/heating company "booked until December" another one "call you January". Another one sorry we are booked I will call you if something opens up.
Could go forced air (we dont need AC in my climate in Alaska so forced air not hard) but #1 theres only 1 local sheetmetal company that does HVAC ducting locally and with hydronic since I already have the new 50 gallon water heaters seems the way to go but obviously traditionally are with boilers so I can get people barking at this idea. Before I get judged duplex has ICFs, 3" foam ext wall including rim joists, attic (plus blow in). Triple pane windows. By all means could probably heat the place with a candle but is there anything in the plumbing code that prohibits this? I cant really find answers dont mean to be lazy.
Building the system wont be hard. Small units and well insulated really could get away with one zone per unit. Its really my only option and its affordable. One unit a 2/1 the other unit 1/1 so we are not talking high hot water usage each unit has their own water heater.
Several people have built these systems on youtube with double the sq footage for one water heater. One guy said his only kicks on 3 times a day and he is in northern state. Urethane foam, triple pane windows, ICFs, half his sq ft I think this is plausible.
Does anyone agree with this article? https://baileylineroad.com/hydronic-heating-with-water-heater/
