A funny for the day
mmmarvel
Houston, TX
Tools Explained
1. DRILL PRESS: A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
2. WIRE WHEEL:Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light . Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh ****!'
3. SKILL SAW:A portable cutting tool used to make studs too short or electical cords a smaller length. Name does not necessarily imply the intellect of the operator.
4. PLIERS:Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
5. BELT SANDER: An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
6. HACKSAW: One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
7. VISE-GRIPS:Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
8. OXYACETYLENE TORCH: Used almost entirely for lighting various flammable objects in your shop on fire. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race.
9. TABLE SAW: A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
10. HYDRAULIC FLOOR JACK:Used for lowering an automobile to the ground after you have installed your new brake shoes , trapping the jack handle firmly under the bumper.
11. BAND SAW:A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
12. TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of everything you forgot to disconnect.
13. PHILLIPS SCREWDRIVER:Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
14. STRAIGHT SCREWDRIVER :A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
15. PRY BAR: A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
16. HOSE CUTTER: A tool used to make hoses too short.
17. HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
18. UTILITY KNIFE:Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes or appendages, but only while in use.
19. SON-OF-A-BITCH TOOL: (A personal favorite!) Any handy tool that you grab and throw across the garage while yelling 'Son of a BITCH!' at the top of your lungs. It is also, most often, the next tool that you will need.Hope you found this informative.
mmmarvel,
Agree with fatboy and others, ...that list is purdy darned funny
and all too true!........I have some of those same tools, and their
uses [ and results ] are identical to mine.
Can I add one more to the list... ?
20. A BFH-9000:Otherwise formally identified as a "big friggin'
hammer".........The " 9000 " designation is to indicate that it is the
most current model..........This "BFH-9000" can be, and most
commonly, is used for all kinds of tasks and jobs that a regular
hammer just can't do........Tasks like opening stuck doors,
...removing stuck bolts, ...driving nails in to things that nails
should not be driven in to, ...fixing an ex's car, in a multiple of
ways :devil, and other seemingly simple tasks that are fixed
rather quickly with the manly swing of a good `ol BFH-9000.
Why I'll bet that most menfolk on here already have one of
these invaluable tools in their arsenal, ...eeeeeerrrr, tool
box! :cool:
Can you think of some more to add to the list?
21: hand held router, a tool for destroying super expensive peices of hardwood, and poking holes in dry wall.
22: Lathe, a large permantly placed peice of equipment designed to rip loose clothing off the body of anyone nearby.
