A Look Back: The Evolution of Southern Yellow Pine Span Tables
Introduction
In the realm of construction and building codes, few events have had as profound an impact as the revision of the Southern Yellow Pine (SYP) span tables in the early 2010s. This article takes a retrospective look at this significant development, tracing its origins, the process of change, and its implications on the building industry.The Prelude to Change
Southern Yellow Pine has long been a staple in American construction, prized for its strength and versatility. However, changes in forestry practices led to variations in the wood's characteristics. By the early 2000s, it became evident that the newer SYP did not possess the same density and strength as its older counterpart, primarily due to faster growth rates and a resulting looser grain pattern.The Turning Point: 2013 Design Value Revisions
The critical turning point came with the Southern Pine Inspection Bureau's (SPIB) comprehensive testing and subsequent publication of new design values in 2013. This rigorous process, which adhered to the consensus standard ASTM D1990, involved destructive testing of more than 7,400 full-size samples of commercially produced SYP.On February 11, 2013, SPIB published Supplement No.13 to the 2002 Standard Grading Rules for Southern Pine Lumber, encompassing new design values for all sizes and grades of visually graded SYP lumber. These changes were officially approved by the Board of Review of the American Lumber Standard Committee following a hearing on January 30, 2013.
Implementation and Impact
The new design values became effective on June 1, 2013, marking a significant shift for the building industry. This included a 20 to 30 percent reduction in key design values such as bending, tension parallel to grain, compression parallel to grain, and modulus of elasticity.The Southern Forest Products Association (SFPA) was instrumental in facilitating this transition. They released an updated set of span tables on July 24, 2013, which included comprehensive listings for maximum spans for SYP joists, rafters, headers, and beams.
