A sewer line runs through it, staring Robert Redford
SCBO1
MID WEST
Existing lot with an active sanitary sewerline in a utility easement running through it. Owner is proposing a building on top of the utility line. Plans call for rerouting the line to a new built SS line which will be in another utility easement. Would you issue a BP before the UE is vacated or after it's vacated. Keep in mind that if you vacate before issuing the BP you still have an active sewerline nolonger in an easement and at some point the new SS has to built and take over!
Just curious how you fellas do it!
I would issue the Building Permit but require a statement on the plans that no approval for foundation pour will be issued until the existing SS line is disconnected, the new rerouted SS line is built, inspected and operational, the old UE is vacated and (if needed) the new rerouted UE is recorded.
Please note that I'm an architect, not a building official. But I've seen chicken-vs.-egg scenarios where the developer first needs to have the BP in order to secure the construction loan which will then finance removal of the SS line.
Issuing the BP, but requiring evidence of easement vacation and SS line rerouting prior foundation pour, still helps ensure the ultimate public interest goal is met while giving the owner the flexibility they need.
On a separate note, here in one of the biggest cities in So Cal, we once got approval to build a HUD apartment complex that straddled an active public works storm drain line, with an active easement. (HUD is very particular about easements and ownership issues.)
The solution is that the line and easement passed underneath/through our 2-story high lobby, which was designed with a sacrificial floor slab and deepened footings to eliminate surcharge loads. We had extra large entry doors at either end of the lobby, and the lobby doors were not used as a means of egress. Point is, if the pipe ever needed replacing, we could open up the doors, drive in the equipment, sawcut the slab and dig as-needed to access and repair the storm drain line, all without evacuating the tenants.
I was thinking "chicken or the egg too." I think a BP with conditions makes the most sense, then they have a permit to do the work, starting with relocating the sewer line.
Or just make an omelet and forget the fried chicken... (hope for the best)
Nice guys finish last. Been there, done that. Sure the intentions are good, promises are given and then it can all turn to shlt. If they need a permit to get a bank loan it'll have to be a sewer permit. If the bank doesn't agree with that and you choose to accommodate, at the least there should be a massive performance bond.
