I think "lounge" in this case is referring to a slightly different use. Note A3.8.2.3 lumps "lounges" in the same general category as lunch rooms and cafeterias.To confirm an occupant load in a lounge owned and operated by a passenger station, would it be a space with non-fixed seats (0.75m2 per person) or lounges (1.85 m2 per person) ?
Assume 100m2. 0.75m2/person will lead to an occupant load of 133. Same area at 1.85 is 54.Thank you for clarifying and referring the notes. In regards to restrictive, wouldn't a smaller square area per person be more restrictive or are you taking into account other provisions ?
Not in this case. Would this section apply to an entire building in an intermodal station?Is this a rapid transit station under 3.13?
That section is an Ontario specific section, so I don't have a lot of experience with it. I would say it only applies to the part of a building that is being used as a rapid transit stations based on the scope and the definition of rapid transit station.Not in this case. Would this section apply to an entire building in an intermodal station?
