NH09
Does anyone out there have regulations regarding Accesory Dwelling Units (in law apartments)? I am curious to see if anyone has an ordinance that actually works. We have a local ordinance and it is very difficult to enforce when denied by the Zoning Board of Adjustment. I have copied the section below for everyones reading enjoyment:
02.6 ACCESSORY DWELLING UNITS (2008) (allowed by special exception)
A.In all cases involving an Accessory Dwelling Unit (ADU), the Board of Adjustment in addition to the criteria contained herein shall consider the following requirements:
1.The primary dwelling unit shall be owner occupied.
2.The ADU must be developed in a manner which does not alter the character or appearance of the principal use as a single-family residence.
3.The ADU is intended to be secondary and accessory to a principal single-family dwelling unit.
4.The ADU shall not impair the residential character of the premises nor impair the reasonable use, enjoyment and value of other property in the neighborhood.
5.Only one ADU shall be allowed per a property.
6.The ADU shall not exceed 700 SF total space.
7.The ADU shall include no more than one bedroom.
8.Adequate off-street parking must be provided.
9.No additional curb cuts shall be allowed.
10. Any necessary additional entrances or exits shall be located to the side or rear of the building whenever possible.
11. Attached accessory dwelling units shall be designed to allow for re-incorporation into the principal dwelling unit.
12. Attached accessory dwelling units shall have and maintain at least one common interior access between the principal dwelling structure and the accessory dwelling unit.
13. An ADU shall be located in an existing or proposed single-family home or detached accessory structure.
14. All criteria of the zoning district including lot sizes, frontages, yard requirements and height requirements must be met.
15. An existing nonconforming residential use shall not be made more nonconforming.
16. An ADU must meet all current local and State Building, Fire and Health Safety Codes.
