Inspector 102
Silver Member
Isn't there a code reference that prohibits one bedroom being access through another bedroom? I can't find anything and am wondering if this is a child welfare issue or building code issue I just can't find.
It's a real estate issue.Inspector 102 said:I can't find anything and am wondering if this is a child welfare issue or building code issue I just can't find.
We have not adopted the IPMC and would not have the problem, but I am curious as to how those AHJs that have adopted the IPMC would handle the problem should it arise.mtlogcabin said:So brudgers designs a house with access from one bedroom going thru another which is not prohibited in the IRC or IBC. fatboy has to issue the permit because it complies with the building code. On the day of final inspection he issues the CO and then the violation letter for the property maintinance code :banghdDon't you just love the consistency in the codes
IRC 2009mtlogcabin said:So brudgers designs a house with access from one bedroom going thru another which is not prohibited in the IRC or IBC. fatboy has to issue the permit because it complies with the building code. On the day of final inspection he issues the CO and then the violation letter for the property maintinance code :banghdDon't you just love the consistency in the codes
Doesn't the word 'every' have the same effect as the IPMC?R310.1 Emergency escape and rescue required. Basements, habitable attics and every sleeping room...
The IPMC ? is about access. 310.1 of the IRC seems to only address egress and a single egress window would apply.imhotep said:IRC 2009Doesn't the word 'every' have the same effect as the IPMC?
I take the point. Two bedrooms, both provided egress windows with one bedroom accessed through an adjoining one.gbhammer said:The IPMC ? is about access. 310.1 of the IRC seems to only address egress and a single egress window would apply.
Doesn’t seem right that’s for sure, the only time you’re ever likely to even see it is in shotgun homes that were built after the civil war up until about the depression.imhotep said:I take the point. Two bedrooms, both provided egress windows with one bedroom accessed through an adjoining one.
Funny. Is convenience regulated?righter101 said:Can't you access the back bedroom through the EERO?
Good point and I believe you are correct.Back to the original point, couldn't you use IRC 102.2R102.2 Other laws. The provisions of this code shall not be
deemed to nullify any provisions of local, state or federal law.
And consider the IPMC as a "provision of a local law"... and thus not allow the configuration under the IRC. Legal logic, I think makes sense. Allowing them to build it, then telling them it is in violation of another statue would be contrary to the IRC.
It is not two bedrooms. It's a suite.fatboy said:Unless you have adopted the IPMC, 404.4.2 prohibits accessing a bedroom though another bedroom as the only means of access.
