access to elevated appliances
retire09
Silver Member
Alaska
What code section allows a unit heater suspended from the ceiling 18' above the floor or a unit mounted to a wall to be accessed from the floor by a portable ladder?
Good question!.....Over 16' I don't think I have an issue requiring permanent access....Anything lower is kinda left in limbo....I will wait for the experts on this...
306.5 Equipment and appliances on roofs or elevated structures. Where equipment requiring access and appliances are installed on roofs or elevated structures at a height exceeding 16 feet (4877 mm), such access shall be provided by a permanent approved means of access, the extent of which shall be from grade or floor level to the equipment and appliances' level service space. Such access shall not require climbing over obstructions greater than 30 inches (762 mm) high or walking on roofs having a slope greater than four units vertical in 12 units horizontal (33-percent slope). Where access involves climbing over parapet walls, the height shall be measured to the top of the parapet wall.
becasue it has been that way for fifty years, and have never seen a permanent access to an appliance up in the air.
They typically use a lift to change them out or service them. I suppose the guys in ICE's jurisdiction build their own ladders out of bamboo and twine.
