ETThompson
How do people designate accessory uses on a Life Safety Drawing, or a Code Data Sheet? I've been looking at several projects I've done as well as some others.
First, for the drawing: we have room tags that include the occupancy - do people use the "main" occupancy (say, A-3) and then put "accessory" in parentheses (or not list that it is accessory at all? Or do you list the actual use - like S-1 for a storage area associated with the assembly occupancy?
Likewise, on the code data sheets, we have a summary table of the different areas by occupancy - again, same question as above, use the "actual", the overriding occupancy (ie, the primary to which the accessory is ancillary) or some hybrid of the two?
It seems important to clearly show, somehow, which spaces one is considering as accessory.
Thoughts and comments?
Thanks
Thanks
