tbz
So Call me an idiot, but I can't seem to find the minimum centerline a sink needs to be from the side wall in the bathroom.
A117.1 does not identify that the clear floor space must be centered.30” space centered on the faucet.
That said, your answer is correct I suppose, but the requirement is actually 15-in from fixture center to face of wall.30” space centered on the faucet.
FYI, I confirmed that it does in fact exist - see IPC Section 405.3.1 that I posted above.Thanks,
I know the 30 but for the life of me just can't find the c/L and confirmation it does not exist works for me.
If your project is covered by the FHAG and it is a type (b) FHA bathroom this citation applies. It is on page 9512:So Call me an idiot, but I can't seem to find the minimum centerline a sink needs to be from the side wall in the bathroom.
No, its a straight on approach just the left side is against a wallWhen you say "corner wall mounted", do you mean something like this?
Build a +-20” deep bulkhead (furred wall corner) for the toilet, so that the vanity is recessed into an alcove behind the open side of the toilet. Now there’s plenty of room for the 60” wide toilet clearance, and ADA only requires a 24” wide rear wall grab bar.Tom....If they are both on the same "wet wall" you need about 7'1" finished/ clear to make it work depending on lav sizing FYI.....
I don't see anything incredibly alarming. A few items to measure and verify.
62 inches from toilet wall and 1" off counter edgeWhat is the distance from the side wall to the paper towel dispenser? dispenser height to operating device?
Watch for the 18" on the pull side of the door too...Common issue here...Bathroom layout for reference, the second unit is a mirror of the first, all the fixtures were donated for this project.
