beachmonkey
I am thinking of leasing a space on the 4th floor of a 4 story building in Myrtle beach, SC that hasnt been used in a long time. the building was built in 1982 and doesnt have an elevator to the 4th floor.
the Space will be for low occupancy office/studio (less than 49 people, but usually only 1-2 people) and not open to the public.
I am only going to do cosmetic changes (paint the walls and floor) to the primary area, add an hvac system and put a toilet and sink in the bathroom.
I was told by the city plan reviewer (when i told him my plans) that i need to install an elevator encase a handicapped person needed to get in. the elevator would be 50,000 minimum to install.
I looked up the requirement and spoke to someone at an ADA group and they said that
III-6.2000 Alterations: Path of travel "required to the extent that they are not "disproportionate" to the original alteration, that is, to the extent that the added accessibility costs do not exceed 20 percent of the cost of the original alteration to the primary function area." (20 percent disproportionality limitation meaning they wont require an elevator if it grossly exceeds the total percentage of your budget)
exceptions: the path of travel requirement is not triggered if alteration work is limited solely to the electrical, mechanical, or plumbing system, hazardous material abatement, or automatic sprinkler retrofitting, unless the project involves alteration to elements required to be accessible. (so painting or adding HVAC system doesnt count toward changing path of travel)
my total cost of the bathrooms will be about $500 and ill have to spend $100 (20%) if possible on make the bathroom ada compliant.
My question is... is there something in the international building codes that most USA cities (including Myrtle beach) that goes beyond the ADA requirement?)
