ADA Law question
mwskopf
Kansas
All,
Hypothetical question: ( and this is by no means meant to downplay the importance of having proper accommodations for those with disabilities)
If company X is plodding along in their 70's ish building (with no plans for alterations) and hires a person in a wheel chair, can the disabled person sue the company for not having ADA accessible items (plumbing namely)?
Thanks
I think they can sue, after they go through a reasonsble process of requesting accommodations and getting denied.
I believe you can sue in all cases, but what you get in return (if the plaintiff wins) will vary. In California, a plaintiff can receive monetary damages using the Unruh Act with the Californians with Disabilities Acts as the basis. In most other states, the only thing they could achieve is injunctive relief (i.e., fixing the problem). For claims with the DOJ on ADA violations, compensatory damages and back pay could be awarded; however, the DOJ cannot sue unless negotiations to settle have failed (per DOJ's ADA website).
mwskopf,
I agree with
** e Hilton **……...The new employee would need to
raise awareness, ...make requests to alter to ADA compliance, which
"most likely" would send up red flags as to them not making it thru
their probationary period, and document, document, document,
document...…..IMO, this type activity will not set too well with
leadership after being hired.
mwskopf,
I agree with ** e Hilton **……...The new employee would need to
Title I compliance is required as in reasonable accommodation
Thanks for the link! I checked it out. Seems like the term undue hardship is still a bit nebulus, but I admit it would be unique for every case and difficult to define.
Agreed. The document does go into much greater depth concerning "undue hardship issues" as I continued reading. That part helped a little more.
It is one company of approximately that era, if not older, with multiple departments within -HR, engineering, managers, and execs. What are your thoughts?
Someone has been asleep at the switch to be pleading ignorance this late in the game.
There is always the responsibility for barrier removal regardless of age of building and or public vs. private use. Barrier removal can be as simple as changing the door hardware, adding braille signage at elevators, installing power operated doors, removing furniture to allow more maneuverability and companion seating, lowering a countertop. These are low cost items. When it comes to the big stuff....remodeling bathrooms, widening doorways, changing switch and outlet locations....these might be considered unreasonable hardship depending on the scope of remodel you might be doing (in CA when you hit 20% of construction cost, you have achieved minimum required upgrades). As ehilton said, a large corporate building is different than a mom and pop business...the economies of scale kick in with respect to "hardship" and the income that is generated.
The company should have the employee work from home.
i thought of this by myself and I’m not even an architect.....
