error404
Bronze Member
Is there such a thing?
opcorn
opcorn
The controls on the dryer are to high. How about a combination washer/dryer unitcda said:
Not an Ada person but would say yes on side by sideerror404 said:Thanks!! I already found that site.It says "All Products are ADA Compliant", but that doesn't mean that once they are stacked... they continue being ADA complaint. Perhaps only side by side are ADA complaint.
Never hear of those before...mtlogcabin said:How about a combination washer/dryer unit
Sorry, my title was misleading... I meant ICC ANSI A117.1Uncle Bob said:Welcome to the forum,Hopefully this will help. ICC/ANSI A117.1, (concerning stackables being used as stackables) NO. 611.4 Height Front loading machines shall have the bottom of the opening to the laundry compartment 15 inches minimum and 34 inches maximum above the floor. It is important to note whether your jurisdiction adopted the ADA Standards or the ICC/ANSI A117.1.
ADA is covered legally in the context of civil suits; but, some jurisdictions have adopted the standard (not the guide). If you did not adopt the ADA Standards you should not attempt to enforce it.
Uncle Bob
For those that care; I'm an Architect, but most of my work until recently has been single family homes.cda said:Error404 do you mind saying what you do for a living?
Can't access the linkcda said:welcome anyway we have a few arch e techs on board!!!http://www.thebuildingcodeforum.com/forum/sawhorse-code-talk/11483-peach-pe.html
Yes it is interesting seeing a builder going from residential to commercial!!!!!!!!!!!!!
error404, you do not have permission to access this page. This could be due to one of several reasons:
Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
ansi a117.1 - 2003mark handler said:are you trying to meet ada, ibc, ansi or fair housing guidelines... Yes there are stackable units that can comply to most standards
Don't trust the fruitpeach said:for what it's worth:First, become a sawhorse.. if you don't, you miss alot of what happens.
