nsmarch
Per IBC Section 721.1, “Where materials that change the capacity for heat dissipation are incorporated into a fire-resistance-rated assembly, fire test results or other substantiating data shall be made available to the building official to show that the required fire-resistance-rating time period is not reduced.”
Can someone point me in the direction of where I can find substantiating data that shows adding a sound barrier to a UL Listed floor-ceiling Assembly would not reduce the fire-resistance-rating time period? (ie. adding Homasote 440 to UL L583)
Thanks!
Thanks!
