Hyrax4978
Reading chapter 11 of the IEBC having a tough time discerning what might need to be done to the existing building.
1101.1 : An addition to a building or structure shall comply with the International Codes as adopted for new construction without requiring the existing building or structure to comply with any requirements of those codes or of these provisions, except as required by this chapter. Where an addition impacts the existing building or structure, that portion shall comply with this code.
looking at a building that exists that has a small portion that is three stories. but a larger portion (9,000 sf) is only two stories, ground and third floor. the client would like to add a second floor between the ground and third, plenty of room. because there is a portion of existing building that is already three stories i am looking to see what i may need to do to this existing area to accommodate the new floor area. based on the IEBC its classified as an addition, and the new area needs to comply with the IBC.
What i am wondering is where does the code tell me how to handle the existing stairs in the existing three story area. do they need to meet the full IBC because of the new addition/area, or do they just need to comply with the IEBC which looks like it could be just a smoke enclosure. I would think it would need to meet the full IBC, but 1101.1 is a bit confusing to this.
Thank you,
Thank you,
