Hi, I have an issue with the city and its review of existing conditions.
The jurisdiction is in Oregon, I won't get more specific than that. This project is under the 2022 OSSC.
Background-
I am picking up a project that was filed a few years ago by our firm and that was put on hold while the owner pursued some other projects.
I have a set of plan check comments that includes the city challenging what existing conditions are permitted and unpermitted.
The existing building is several hundred thousand sq. ft of Type VB unlimited area building that is used as an F-1 production facility. There is a small 2-story area in one section of the building, no more than ~20k SF that is office. The general occupancy of the space has changed very little over the years. The building was built and permitted in the late 1990s. There are over 200 permits that have been pulled since then, including over a hundred over the past 10 years. The biggest changes were tenant demising walls were removed as the main tenant eventually expanded to occupancy the entire building, with a lot of MEP and equipment permits related to the production space.
Issue-
In the city's plan check comments that revolve around life safety, they compared the original building occupancy permit against the current office configuration and stated that we have to re-permit every office space, shop, kitchen and other spaces that differ from the 1990s permit.
The problem I have with this is several:
I have ran into this in the past, but have on occasion been able to challenge them by conducting a thorough records request to find permits that covered the so-called "unpermitted" work. This seems patently absurd and a violation of the building code and ORS statutes.
Is it really the architect's job to prove that the existing conditions of the building were in permitted or not? I do not believe the city is acting in good faith and requiring the architect to pull ~30 years of permit history to review - which costs $$$ and may not even be available - is insane. We have gotten quite a lot of heat from building owners when this type of rug pull is done by the city and I would rather not waste time and money on frivolous plan check comments.
Thoughts??? How would you approach this?
Background-
Issue-
- They have not referenced any more recent permits, some of which did in fact permit alterations to the space.
- Their reading of the original office configuration is also full of errors (claiming some offices were unpermitted when they were clearly shown on the original building plans).
- Many of the spaces the city listed as being "unpermitted" are, for instance, where a previous "storage" space was repurposed as a locker room or "shop" space, where there were no actual alteration of the building structure.
- Furniture and finishes such as lockers and floor coverings appear to be exempt from the OSSC permit requirements per chapter 1. However they now want me to include these as part of the area of work which will increase the permit fees to include work valued in these areas - despite the finishes having been installed well over a decade ago!
- None of the so-called "alterations" affect the life safety of the building or egress paths.
