Jim k
I was recently turned down by a city inspector on a like for like change out of an existing gas and electric roof top 2.5 ton package unit at the city's community center. The building official was interpreting building code 407.3.1 (air balance). He claims that an air balance report must be performed to prove a proper percentage of fresh air to the building when the system operates. The original fresh air intake is located on the existing ductwork. The section of the code says nothing about performing an air balance after changeout of equipment. My question is that if we adjust the fresh air intake, what does this do to the validity of the original air balance report of when the system was oringinally put in. There is also the question of if the fresh air ends up needing to be adjusted/modified, can I charge for this, in my opinion, additional work? It's just a simple 4" eyebrow without a damper control. I am not set up to do this air balance work, and will likely have to hire a third party. This was not in the written scope of work when I went to bid the change out. It seems to open up a can of worms in my opinion.
