Sifu
- Joined
- Sep 3, 2011
- Messages
- 3,386
This could go in either residential or commercial...
Residential development full of SFD's and several private aircraft hangers accessory to the SFD's, 2018 IRC/IBC. Single family dwelling, with a detached (or detached) building used as an aircraft hanger for a tail-dragger. IRC applies to "their accessory structures". So does a 3,000sf² attached garage used for a plane rather than an RV count as a SFD accessory structure?
IBC 412.4 has it's very own section for "residential aircraft hangers", which would limit the size to 2,000sf². However, if it is a residential accessory structure, how does a user even get to the IBC? If it is an IRC accessory structure, then what would an IBC residential aircraft hanger be? Is it accessory to a residential structure that is not a SFD? I think these would be IRC regulated accessory structures, same as an RV garage, but since the IBC has a specific section for residential aircraft hangers I am puzzled. I make the distinction between "private" and "not private", but the code doesn't seem to make the same distinction.
