MKALLAY
Good morning,
I have an interesting code question relating to the International Existing Building Code, and wondering if anyone can provide insight.
The scenario involves an existing dormitory building at a private boarding school. The designer wants to modify an existing stairway to provide a landing at primary grade level that will also serve as an accessible entry. Doing this will require removing and reconstructing a portion of the stairway, from the basement level to the primary level, and then from the primary level to the 2nd level. The complication here is that the existing stairway has treads and risers that do not meet the current IBC (10 ½” treads and 8” risers). Constructing the altered portion in accordance with current IBC requirements would present headroom issues.
The designer is pointing to the prescriptive compliance requirements, Section 503.1 has an exception that reads: “An existing stairway shall not be required to comply with the requirements of Section 1011 of the International Building Code where the existing space and construction does not allow a reduction in pitch or slope.” The designer believes this passage will permit him to alter the stair and use the existing dimensions to reconstruct a portion of it. I am not so sure this is the intent of this passage. (My belief is that the portion of stair not changed would be permitted to remain, but any portion constructed new must comply with IBC stairway requirements per Section 1011)
Can anyone offer insight on this? Or perhaps suggest an alternative passage (i.e., anything under work area method?) that would allow the designer to proceed in this manner?
