AMBULATORY CARE FACILITY Emergency power?
mtlogcabin
Big Sky Country
I cannot find any requirements for emergency power in an Ambulatory Care Facility in the I-Codes. Is emergency power required under the Life Safety 101 code?
The requirement comes from Article 517 in the NEC.
Yes, emergency power is required "if" the patients are
rendered incapable of self preservation, or taking action
themselves if they become anesthetized........Refer to
Article 517.2.........My reference is from the `08 NEC.
But what code and edition is this designed to??
SECTION 403 HIGH-RISE BUILDINGS AND GROUP I-2 OCCUPANCIES
403.4.9 Emergency power systems. An emergency
power system complying with Chapter 27 shall be provided
for emergency power loads specified in Section
403.4.9.1.
SECTION 408 GROUP I-3
408.4.2 Power-operated doors and locks. Power-operated
sliding doors or power-operated locks for swinging
doors shall be operable by a manual release mechanism at
the door, and either emergency power or a remote
mechanical operating release shall be provided.
Exception: Emergency power is not required in facilities
mark handler said:
SECTION 403 HIGH-RISE BUILDINGS AND GROUP I-2 OCCUPANCIES403.4.9 Emergency power systems. An emergency
403.4.9.1.
Depending on the circumstances and code it might be a "B"
In the 2012 I-Codes, I don't believe that requirement kicked in for Group I-2 (where ambulatory care facilities would be under, I believe). In the 2015 I-Codes, look at Section 2702.2.6. Note that the section is controlled by the IFC committee [F] so you will probably find the same language in the 2015 IFC. And chances are, this probably originated in NFPA's life safety code before someone proposed it to the IFC. The 2015 I-codes can be viewed for free at ICC's website.
Well welcome!!!!
That is true, but I was giving info based on very little info. If it is a B thereare No Emergency power requirements
mtlogcabin said:
Sorry I did not mention it fall into the "B" occupancy category
No emergency power required but they could do what my neighbor does, he is taking care of his wife at home. Portable emergency gas generator.
From the NFPA 101, Section 3.3.134.3: A business
occupancy is “used for account and record keeping or the
transaction of business other than mercantile.”...........This
is a very broad definition, but as it applies to health care,
the definition refers to a facility where no one stays
overnight and where three or fewer individuals are
rendered incapable of self-preservation at any given
time by virtue of their treatment".
If 4 or more individuals are rendered incapable of self
preservation at any given time, by virtue of their
treatment, then Emergency Power is required.
Typically an ambulatory care facility is B occupancy. That's usually to point, to construct a facility for performing minor procedures without the expense of hospital (institutional) construction. Also IBC 2012 has provisions in 422 specifically for ambulatory facilities (nothing for emergency power though). Life Safety Code MAY have to be followed if the owner of the facility gets reimbursement for procedures through Medicare. The size of the building plays into it as well. Emergency egress lighting has to be provided, there is a break point where a generator is more cost-effective than battery backup fixtures. It also may be the owner's preference to have a generator, whether or not it is required. That's my two cents, hope it helps.
