ADA says that an ambulatory stall must be 60" deep minimum. In 604.8.2.2, it states that Toilet compartment doors shall comply with 404, except that for a latch side approach the door clearance can be reduced to 42". I have a plan reviewer telling me that in addition to the 42" on the outside of the stall, I also need to provide the 48" maneuvering clearance on the inside of the stall per 404.2.4.1, and that the toilet cannot encroach.
In my entire 25 year career, I don't think I have ever seen this requirement enforced or even questioned. I have seen dozens of ambulatory stalls that were designed with the 60" minimum depth per the diagram in the code without issue. If this is in fact a requirement, then why did ADA even provide a minimum 60" stall depth? That would be impossible to achieve as it would only leave you with 12" for a toilet (60"-48"=12"). A 12" deep toilet does not exist.
I feel like the 48" maneuvering clearance is intended for people in wheelchairs, but an ambulatory stall is not for people in wheelchairs. It seems like common sense, but I can't find support for that in the code.
What am I missing here?
