Ambulatory stall minimum dimensions
ADAguy
ADA says "60" min. length, Plumbing code says "24" min. length in front of WC, even with door swinging out, 24" won't accommodate a walker.
Isn't a longer dimension (+48") in front of a wc required in any code?
Guess I must go to a "best practices" eh?
Try this on for size, 36" x 24" clear floor space vs. (+360lb) individual with a 56" waist, try turning around or backing into an ambulatory stall when the accessible stall is occupied?
If the 24" were in fact 48" it would be easier or if you used a wall mount flushometer vs a tank you would gain useable clear floor space within the 60" minimum depth, of course this assumes best practice vs minimums.
Legal vs logical, "oh well"
mark handler said:
Yes they do if they want a permit
They only have to show compliance to the code to get a permit, they don't have to listen to my suggestions for making something better than the worst you can build by law...
Ambulatory stall minimum dimensions are in the codes and standards. As I have always said, enforce the codes and standards in force where you are.
