princeofpen
- Joined
- Aug 11, 2011
- Messages
- 62
IF an existing building is over the height/area calc and an increase in floorspace needed can it be added to using what code section? OR would the separate buildings on the same lot IE 4 walls with fire separated roof structure be the only way?
Currently proposed by design is 3 walls constructed added to existing building with a rated assembly of 2hrs between what was the existing building and addition.
Thoughts regarding your plan review/compliance path would be appreciated. POP
