It doesn’t, you have to use a tape measure on site.What section of the code tells you what the span of stringers are?
I think the stringer boards would have had to be cut out of a 20' board. I don't think they were quite 22'... but I only measured horizontally, so I don't know.Span is measured horizontally so it must have been 22' long?
I just haven't seen sawn lumber over 16' in a long time....I think the stringer boards would have had to be cut out of a 20' board. I don't think they were quite 22'... but I only measured horizontally, so I don't know.
So, if is more than 6' horizonal and stringers are made from a 2x12 it needs to be engineered if there is no mid-span support?40 psf live load is called out IRC. I know it won't span at longer than about 8' at 12" O.C. because I calculated it as a 2x6 in BC Calc. The DCA 6 says not to go more than 6'. Going by that, if it's over the 6' to 8' range, I make them prove it will span.
Trust me, if you try to calc it, or use a joist table for a 2x6, it's not even close.
Yes, pretty much. I would allow up to 8' if they are at 12" O.C. as borderline because it will span according to BC Calc.
I don't know how you are supposed to calc stringers.
If the treads are considered stiff relative to the (cut) stringers, then the load on a tread will be spread approximately evenly across all the stringers. In which case the tributary width should be just the total width divided by the number of stringers.The 12" tributary only truly applies to the middle stringers, but again, it is a conservative number that I can apply to the outer stringers as well.
IMHO only if the treads are 2x wood. If they are 5/4 or trex-type composite it would be flexible.I'm not sure which model is more realistic, but the stiff tread model seems plausible to me.
If you size them the way I demonstrated, you are covered either way because the inside stringers are the ones I size in that method, and just use the same size for the outer stringers. It is extra conservative, but if they don't like it, they can hire an engineer.So how do you know if the inside stringers comply with on 1x12" stringers.
I don't know why the code would be silent on stringer span. It's kind of a giant cop-out.Why is the code silent on stringers? Does that mean they all need to be engineered?
They are nowAre the pipes plenum rated?
