Another Change of Use & Function
globe trekker
Greetings to all!
I have a an existing small wing, in an existing hospital, that is currently being used
as office spaces (7 total). I am assuming it is a "B" Occ. Group, but not sure!
The plans are to convert these office spaces in to Patient Rooms, with only 1 of the
7 being designated as an ADA Patient Room & ADA Patient Toilet Room. All 7 will
have "new" Toilet Rooms in them. We are using the 2006 Edition of the I-codes
and the 2003 Edtion of the ICC/ANSI A117.1 Standard.
QUESTION # 1: Do all of the "new" Patient Rooms have to be fully ADA compliant,
including the "new" Toilet Rooms, or just the one designated (RE: Section 3403.1)?
Any other relevant information, experience or code sections will be greatly
appreciated! Thank you! :)
International Building Code 2009 Commentaries
1107.5.3.1 Accessible units. At least 10 percent, but not less than one, of the dwelling units and sleeping units shall be Accessible units.
While the anticipated percentage of patients in general-purpose hospitals is typically higher than 10 percent, there is also an anticipation that many of the patients will be routinely assisted by staff. Section 1109.2, Exception 5, exempts the bathrooms associated with critical care or intensive care. Sections 1104.3.2, Exception 2 and 1107.3, Exception 2, exempt any 44-inch (1118 mm) doors from the maneuvering clearance on the inside of the Accessible patient sleeping room. Wider doors are required in Section 1008.1.1 for Group I-2 facilities where there is movement of patients in their beds. In the case of psychiatric facilities, detoxification facilities or residential care/assisted facilities, it is less likely that the typical patient will be physically disabled.
Thanks mark h. for the input and code sections, ..a BIG Help!
QUESTION # 2: What about common spaces/corridors & operable parts,
..does Section 1109.13 = Controls, operating mechanisms and hardware, 2006
IBC apply to the hospital nursing staff? I have a "new" thermostat being installed
outside of the required ADA/Accessible sleeping unit, in a corridor. Also,
Section 308 & 309 in the 2003 Edition of ICC/ANSI A117.1.
Yes any new controls should be accessible
But you can make the case that only mantaniance personal will control it
