globe trekker
- Joined
- Oct 19, 2009
- Messages
- 1,739
Greetings to you all!
I have a Commercial project where only MOE is required (less than 50 occ. load,
fully sprinkled, Type B occ. group, approx. 2,800 sq. ft. - NET).
The required one MOE (the main front entrance) is ADA/Accessible compliant.
Towards the rear area of the tenant space is another indicated MOE door,
with Exit signage and Emerg. lighting. The ADA/ Accessible Men's restroom is
directly in front of the 2nd MOE door.
In reading Section 1007.1 in the 2006 IBC, the contractor & RDP have met the
requirements for providing the one "required" ADA/Accessible compliant MOE
door from this tenant space. Customers & employees and anyone wheelchair
bound could exit out of this 2nd door, however, the wheelchair bound person
could not reach grade level because there is no ramp from the rear sidewalk
down to grade level.
QUESTION # 1: If Exit signs indicate this 2nd door as a MOE; (or other
doors indicated to be Exit doors) , does it, or they have to be fully ADA/
Accessible compliant?
Please cite any applicable code sections. We are using the 2006 I-codes!
Thank you!
Thank you!
