Carlos Adrian Rodriguez
I hope this forum can help me with Section 404.3 of ANSI A117.1 2009.
FYI: Section 404.3 of ANSI A117.1 2009 and ADA 2010 don't have the same requirements.
We are currently working on providing accessibility to a Police Precinct. We are calling for a new wheelchair lift to be located indoors, in the vestibule, with an automatic door as per 410.2.1. However, existing fire alarm panels will need to be relocated if door maneuvering clearances are required. Therefore, I need to determine if we can make use of section 404.3 Automatic Doors EXCEPTION, which stipulates that automatic “Doors, doorways, and gates designed to be operated only by security personnel shall not be required to comply with Sections 404.3.2, 404.3.4, and 404.3.5.” Thus, my questions would be:
- Can police officers be considered security personnel?
- What changes to the design of the automatic door would be required to indicate such door has been "designed to be operated only by security personnel", the police officers?
This way, we are seeking the wheelchair lift automatic door to be except from having to comply with Section 404.3.2 Maneuvering Clearances, and won't need to relocate the Fire Alarm Panels.
Thank you.
Thank you.
