Robert Ellenberg
I see it done occassionally, usually where a wire is left inside a wall because the final location of a wall mount light fixture is not determined at roughin and they later cut out the drywall and mount a box on ears or with the plates than bend in the tabs. However, they are always referred to as old work or remodel boxes and if I remember correctly, when you read the manufacturers specifications on those boxes they also refer to existing walls, etc. in describing them. Using them also mean the boxes are secured to the drywall or paneling rather than the framing.
Opinions or definitive statements from the codes concerning their use in new construction?
