Hotel, 3 story building, sprinkled, wood construction Type VA. IBC 2006/2009
Looking through the code sections, I do not see anything that would prohibit the shaft walls from bearing loads or being structurally independent from the rest of the structure. If anything, Fire Barrier Continuity states the wall goes from floor to underside of floor above, would suggest the shaft wall can be built at least on this deck.
However, I get the feed back these things are supposed to be independent, etc. What am I missing, please cite.
What I am proposing to do is install blocking in the shaft wall and hanging joists up against the wall?
thanks
thanks
