Apartment buildings
I am assuming CRC is California?
California Residential Code:
1.1.3 Scope. The provisions of this code shall apply to the construction, alteration, movement, enlargement, replacement, repair, equipment, use and occupancy, location, maintenance, removal and demolition of every detached one-and two-family dwelling, townhouse not more than three stories above grade plane in height with a separate means of egress and structures accessory thereto throughout the State of California.
Exception: Live/work units complying with the requirements of Section 419 of the California Building Code shall be permitted to be built as one- and two-family dwellings or townhouses. Fire suppression required by Section 419.5 of the California Building Code when constructed under the California Residential Code for one- and two-family dwellings shall conform to Section 903.3.1.3 of the California Building Code.
MikeC said:
I am assuming CRC is California?California Residential Code:
Yes, sorry. Its Ca.
Apartment buildings are under the of the CBC, unless they fall under the exceptions listed above.
you may also note CBC chapter 11A
