hughdint
I have an Issue with a laundry room that is within a Type A dwelling unit.
We are not providing washers and dryers and we have enough room within the laundry room to provide a turning space without the fixtures installed.
When/if a washer and dryer is installed in the unit it will likely encroach on the turning space.
The doorway is wide enough (4' opening) for a "T turn" to work in this situation but it would need to poke out of the doorway.
I have seen commentary that says that the turning space is required within the room or space but I do not see where it says that in the actual text of the code.
Note that these doors do not have latches only magnet "catches" at the top to keep them closed but they require very little force to open.
Also, this is in NC so we are under ANSI 117.1.
Can a turning space cross the threshold of a doorway (no change in plane)?
