Approved Barricade and Landing?
PaulR
Detroit
In our Michigan Building code here is the section requiring a barrier at stairs that continue below exit discharge:
1022.8 Discharge identification. An interior exit stairway
and ramp shall not continue below its level of exit discharge
unless an approved barrier is provided at the level of exit discharge
to prevent persons from unintentionally continuing
into levels below. Directional exit signs shall be provided as
specified in Section 1011.
My question is: Does there need to be a landing between the barrier (in this case a swinging gate) and the stairs going down? I've seen many examples where the gate is placed directly at the top of the stairs to the basement but it seems to me that some type of landing would be necessary for those coming up from the levels below. Granted there is always plenty of landing space on the other side of the gate.
And the gate would generally swing in the direction of egress travel - in this case away from the stairs.
