Okay folks, I'd like to reopen this thread and see if we can have some more intellectual discussions about this. In my opinion, gbhammer was most certainly on the right track with their opening statement. Where a design professional chooses to reduce the minimum outdoor air rates from IMC Table 403.3, it is the responsibility of the code professional to verify compliance to those alternative methods, not just allow a simple note on the plans that states "I comply". BTW, in my juristiction, we do require electrical, mechanical, plumbing, and structural calculations, and we review them all for compliance to the applicable codes.
First, the codes. The 2009 International Existing Building Code references ASHRAE 62, Indoor Air Quality (IAQ) Procedure in section 709.2. The 2009 International Mechanical Code indirectly references ASHRAE 62, IAQ Procedure in section 403.2 (exception) by stating “where a RDP demonstrates that an engineered ventilation system will prevent the maximum concentration of contaminants from exceeding ….” These code sections will allow the use of ASHRAE 62 IAQ procedure.
Now the questions. 1- Are gbhammer and myself the only ones who have been approached by an air filtering manufacturer (or design professional) requesting to use this procedure (as a selling point for their product)? 2- Are gbhammer and myself the only ones asking for the documentation required to accurately evaluate this procedure? This procedure will attempt to significantly reduce the minimum outdoor airflow rates provided in IMC Table 403.3.
Food for thought … direct quotes from AHSRAE 62.1-2007 Appendix B
“At present, no single organization develops acceptable concentrations or exposures for all indoor air contaminants, nor are values available for all contaminants of potential concern.”
In reference to Tables B-1 and B-2, “Meeting one, some, or all of the listed values does not ensure that acceptable indoor air quality will be achieved.”
In reference to Table B-2, “ASHRAE does not recommend their adoption as regulatory values, standards, or guidelines.”
