I'm working on an assisted living project with two levels of care: One level is classified as Group I-1 (Assisted Living Facilities) and the other is Group I-2 (Nursing Homes). Each level has its own courtyard. The Group I-1 is just residential, but it is adjacent to a community building separated by a fire wall. The Group I-2 also adjoins the community building and is separated from it by a fire wall; however, the Group I-2 has it's own internal community areas called "neighborhoods." This is where I'm having some difficulty in regard to occupant load.
For the Group I-1, the occupant load isn't too bad and the the egress system can handle it, and the occupant load for the community building is also manageable within the designed egress system. However, the Group I-2 nursing home is a problem. There are only 48 sleeping units, but based on gross area, the occupant load is 175. Now, add in the "Neighborhoods," which are like very large living/dining/kitchen areas at about 1,600 sq. ft. each. Using the unconcentrated assembly OL factor for the net floor areas, the occupant load increases by another 313, for a total of 488. Now, the courtyard can only egress through the building, and if I add that occupant load (using the unconcentrated assembly OL factor) into the mix the total occupant load for the building will be somewhere between 800 to 900--for a 48 room nursing home.
Now, could these "Neighborhoods" and the courtyard could be considered "inpatient treatment areas" at 240 sq. ft. per occupant? This will drop the occupant load way down to a more manageable level--to about 200 occupants total for the building.
Anybody else have other solutions that have been accepted?
Thanks
Thanks
