Overlapping astragals are not allowed to impede egress, which I'm sure you already know. I'm about to go all hardwarey right now so get ready.
If the doors have panic hardware, there are 2 typical scenarios. In both cases, the overlapping astragal will impede egress regardless of which leaf it is installed on. The astragal can also have a negative effect on security. Read on if your eyes have not glazed over yet.
Scenario 1) Vertical rod panic hardware (either concealed or surface-mounted) on both doors - If there is an overlapping astragal installed on the exterior, the door that is being overlapped by the astragal can not be opened unless the other door is opened first. This is not acceptable by code. I can find you a reference if you need it.
Scenario 2) Rim panic hardware on both doors, with a removable mullion - Again, the door being overlapped by the astragal can not be opened unless the other door is opened first.
In both of these cases, if both doors are opened, and the one with the astragal closes first, the other door will not close because the door will sit open on the astragal.
3) In very rare cases, you will see a mortise panic device (latches into the edge of the other door) on one leaf, and a vertical rod panic (latches top and bottom) on the other door. In this case, you could have an astragal attached to the door with the mortise device, overlapping the door with the vertical rods. If someone pushes the door with the vertical rods, it will push the other door along with it, so it isn't usually an egress problem. But you will have the same security problem of the wrong door closing first unless there is a coordinator installed. Coordinators don't work well, and I don't recommend this application. Like I said, it's rarely used.
There is a photo here of 2 vertical rod panics with an astragal:
http://www.idighardware.com/wordpress/wp-content/uploads/2009/07/svr-with-astragal.jpg. The astragal is on the inside, but you have the same problem. If you push on the door to the right, it won't open unless the door on the left is opened first.
If that's not clear, let me know. I can find more photos.
