We are re-evaluating a few things. Specifically at what point do you change requirements from the "standard way of doing it" in regards to sheds and detached garages.
Specifically sheds have now grown from 8x8 to 10, 12, 14 by 10, 12, 14 feet and greater these days. Our shed handout just says to give us some plans (well, within reason) but remember to use either a 4" slab or concrete piers. The building code this falls under appears in R105.2 Work exempt from permit #1 with floor areas less than 120 sq. ft.
So, at what point do you start plan review of a shed construction and it starts to resemble more a detached garage construction?
If 120 sq. ft., a 10x12 shed would probably need a full 4" concrete slab in order to get anchor bolts within 12" of each corner and 6 feet on center as well as a turned down footing? Full depth protection from frost (42" for our area). Ceiling joists at 16" o.c. to align with roof rafters.
Per R302.1, allowing a 120 sq. ft. shed to be located within 5 feet of a home will require rated walls and eaves????
Thoughts?
I am sure some will say this is overkill for 120 sq. ft. but the code is the code, yes? What about 130 sq. ft., 140 sq. ft, 160 sq. ft????
Thoughts?
