In addition to consulting an attorney, I strongly recommend reviewing the applicable Existing Building Code (IEBC), as it often contains provisions designed to recognize the value of durable, time-tested construction. I recall language to the effect that structures or elements that have "withstood the test of time" are not necessarily required to be upgraded to current code, unless they are being modified or repaired.
For example, the code used the scenarios of a roof damaged by a falling tree: while new trusses must meet current code, the undamaged, original trusses are presumed safe based on their proven performance over time. This kind of clause was to meet the reasonable cost requirement, unless structural safety demands it.
Additionally, if this issue involves a Homeowners Association (HOA) architectural committee, it may be worth asking whether any licensed Professional Engineers (P.E.) or Professional Architects (P.A.) sit on that committee. In many states, including ours, it is a misdemeanor for an unlicensed individual to perform or present themselves as performing architectural or engineering work. If unlicensed individuals are making what amount to engineering judgments without proper credentials, that could present legal and ethical issues—including criminal charges "impersonating a P.E. or a P.A. .
Also, consider discussing the doctrine of laches with your attorney. If the disputed condition has existed since 1993, the legal question becomes: why is it being challenged now, after more than 30 years of apparent acceptance or inaction? Laches is an equitable defense that applies when:
- A party unreasonably delays asserting a claim, and
- That delay results in prejudice to the other party.
The key questions would be:
- What changed now to make the structure or condition objectionable?
- Has the delay in enforcement harmed the property owner (e.g., investments made, reliance on prior silence)?
- Did the HOA or other enforcing body have constructive or actual knowledge for years and choose not to act?
- What "Harm" was caused by this very old act?
These are all highly relevant both from a legal and procedural fairness standpoint. If the structure was acceptable—or at least unchallenged—for three decades, that fact alone should raise serious questions about the legitimacy of the current enforcement action
